My washer fills but will not stop the filling cycle it just keeps filling up and up and up
any ideas
we have tried changeing the fill selection to small loads and it just keeps filling
thanks
any ideas
thanks
Sounds like the water level control is shot.
Especially if turning the unit off or unplugging it stops the water flow.
This tells you that the water valves themselves are OK.
The way it works is, it is a pressure switch.
It has a tube that runs to the bottom of the tub.
Water rises in this tube as the washer fills, this increases the air pressure in the tube.
When the pressure reaches the set point a switch activates, this turns the water off and begins the agitate cycle.
So the problem is
thanks for that if that doesnt work then i can assume its the switch the sending tube is talking to is bad correct??
[COLOR=Blue]thanks for that if that doesnt work then i can assume its the switch the sending tube is talking to is bad correct??[/COLOR]
Not quite sure what you mean. The switch is part of the level control.
You did not include a Model Number so I could not look for a wiring diagram.
LT5000xsn2
how do I access the tube, to check it?
could it be the fill settting switch is bad?
thanks again for your time
buy you a pina colada when you come to hawaii!!!
Here is your parts breakdown
Replacement parts for WHIRLPOOL LT5000XSW2 | AppliancePartsPros.com
One end is Item 10 in the Washer/dryer control section
Other end is Item 11 in Tub & basket section
Here is a manual which should help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf
And here is a decent wiring diagram, may not need it now but might come in handy in the future
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203388366.pdf
