Thin Twin Washer/Dryer combo stuck in closet
Hi
My washing machine sprung a leak. The machine is part of a Thin Twin stacked washer and dryer. The unfortunate thing is that it is located in a closet with very tight dimensions.
Rocking the machine to move it will not work as there is not enough clearance in the closet to get it to move.
Does anyone have an idea as to how to get this thing out of the closet so I can trouble shoot? (I’m guessing its a hose/fitting issue) I can get it approx 1/2 off the floor by tilting it but that is it.
Thanks… Alan
Check your local hardware store or building supplies store for a set of thin rollers that you may be able set underneath the machine, and then be able to roll it out.
They make these for refrigerators but I don’t see any reason why they might now work for your machine.
