Roper electric dryer runs hot all the time, no low or medium heat. Need new thermostat? A job for owner?
Replacement parts for WHIRLPOOL RES7648KQ0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406692.pdf
Here is a good site with basic dryer repair info
http://www.applianceaid.com/dryers.html
[COLOR=Blue]A job for owner?[/COLOR]
Depends on how handy you are and how much effort you want to put in.
[COLOR=Blue]
Need new thermostat? [/COLOR]
This is a possibility. The Operating Thermostat has a small heater built into it, on lower heat settings this heater is turned on. This adds heat to the thermostat, it turns off more often and this reduces the dryer heat.
So if it is open you get only high heat.
The thermostat’s heater also has a variable resistor (cycle switch) in series with it, this varies the heat output of this heater.
First check your vent system
Undo the dryer from the exhaust
Run a load
If the unit now has low heat then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Unplug the machine for the following;
Next remove the wires from the main heating coil. Measure with a meter from each heat contact to ground. Should be an open circuit. This is checking for a grounded element re: it has sagged or broken and is touching the case so it is always on. You could remove the heater assembly and check it visually.
Next remove one wire from the thermostat’s heater and measure it’s resistance, Should be approximately 7,000 ohms.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
very helpful - thanks
