Thermostat Wiring
Brand:Sears Kenmore / Whirlpool
Model Number: 106.50589001
Main Symptom: Freezer cold fridge warm Freezer fan not running but know fan works
What happens & when: I have replaced both Thermostats with part 2203251 and wonder if anyone knows the correct wiring. The fan does not come on but know the fan works as can direct wire it and it will start. I have pictures of the original and new parts.
Error Code (if any): No Codes that I can see
Parts or tests already tried: 2203251
Here is your wiring diagram.Looks like the evaporator fan goes through the air baffle.
Kenmore Whirlpool 106.50589001 Refrigerator Wiring Sheet - 2198632.pdf (657.8 KB)
Also those are 2 different thermostat part numbers!
