I’m sure there is a thermostat for my Amana gas oven, but looking thru the parts diagram, I can’t find it. I have a problem with the oven not getting gas, the stovetop works, but the oven doesn’t bake or broil. Thought of changing the thermostat and the gas shutoff valve, but can’t find the part.
Do the Bake and Broil igniters glow when you choose the Bake or Broil on the control panel?
If not, check for 120 VAC to the Bake igniter while the control calls for Bake. Do the same test for the Broil igniter. Post the results.
Here are the breakdown diagrams and Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
[quote=Gene;232617]Do the Bake and Broil igniters glow when you choose the Bake or Broil on the control panel?
Gene.[/quote]
Yes, I tried them both today after work, and they both glow.
Thanks.
Check if the gas shut off valve (#26 on the diagram) is open.
Gene, is this an automated valve, that could have shut off on it’s own?
I did notice before the oven completely quit, it would take an extra amount of time to reach the correct temperature.
This shut off valve is manual as you can see it on the picture.
If the gas valve is open, most likely the problem is a bad igniters.
Gene,
I ordered the part you suggested, the delivery was fast, installation wasn’t very complicated, the oven’s working fine.
Thanks again for the help.
I saw this forum hoping it was my problem, but isn’t… IS there a thermostat ‘per se’ in the Amana oven model number ARG7302WW or is it all digital? My oven can’t even cook a pizza as it won’t get hot enough!
