Thermistor testing
Brand:Frigidiare
Model Number:LFFH21F7HWJ
Main Symptom:Always running
What happens & when:compresor and evap. fan always running. Is there a way to check thermistor without cutting wires and removing from freezer. If so what are the ohm readings or where is chart from manufacturer
Error Code (if any):none
The thermistor is located on back wall underneath the evap cover on upper right-hand side
(near the wire passageway). Part number is 297110400. There’s a connector on this
harness so the tech does not have to splice into the wire.
Below is a resistance tolerance chart, for testing the thermistor resistance at different temperatures
LFFH21F7HWJ Freezer Service Data Sheet 297246001.pdf (29.8 KB)
297018400 Thermistor.pdf (655.6 KB)
Thank you for that! For some reason mine doesn’t have a connector. I’m not opposed to cut and splice, just wanted to test it before I cut it out. How close to actual inside temp (standalone thermometer) should set temp be to have a thermistor within range?
My KitchenAid fridge has similar symptoms. The model is KSC24C8EYY.
Can you please provide me with this type of information?
