I have a Kitchenaid Dishwaser KUDA03CTBS1 thats four years old that stopped working. I was advised that this models door vent stops opening during the heat/dry cycle and the heat trips the fuse. I ordered a new thermal fuse and door vent and replaced them according to the directions and the power is back on the control panel, but the start light just blinks and the diswasher does not start. Does the blinking start button have a code? How to you run a test so the washer will tell me what the problem is. Oh and is there a reset button I should push?
DU1055.pdf (251.2 KB)
