Thermal cut out and Heating element
I know that my thermal cut out is bad, do to my dryer not turning on. I bypassed and it turned on. I have used a couple of times (carelesss, I know) while at home, and now I have no heat. I am guessing I need the Element that I see comes with a thermostat. I have aslo seen a thermostat kit that comes with 2 other parts. I need to be sure I am getting the right things, if my diagnosis is correct. It the cut out integrated into the thermostat itself, or do I need the Kit? Is there something else that would be the cause to no heat while running, other that the element being bad?
Here are the parts includes a wiring diagram
Replacement parts for MAGIC CHEF CYE2000AYW Dryer - Ele | AppliancePartsPros.com
[COLOR=“Blue”]I know that my thermal cut out is bad, do to my dryer not turning on. I bypassed and it turned on. I have used a couple of times (carelesss, I know) while at home, and now I have no heat. I am guessing I need the Element that I see comes with a thermostat.[/COLOR]
I would not guess, buy of borrow a meter.
[COLOR=“Blue”]
I have aslo seen a thermostat kit that comes with 2 other parts.[/COLOR]
Thermostat kit (Item 5 Section 5) is actually a thermal fuse kit. It comes with 2 thermal fuses. One for gas units and one for electric units. The hi-limit thermostat is included because it should have regulated the temperature so that the thermal fuse did not blow so it is assumed that it is bad.
[COLOR=“Blue”]It the cut out integrated into the thermostat itself, or do I need the Kit?[/COLOR]
I think you need the kit.
[COLOR=“Blue”]Is there something else that would be the cause to no heat while running, other that the element being bad?[/COLOR]
Lots of thinks. Bad thermostat, no 240 volts, bad timer, bad centrifugal switch etc.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
If tghe power is OK
When the thermal fuse blows, you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
