I’ve got a problem with the oven on a Thermador range.
Just in time for Thanksgiving.
First I can’t find the range on the Thermador web site.
The label says:
Thermador
Customer Service 1-800-735-4328
Model P366CS/03
ID 860500001
Serial 39605008371
Oven appears to turn on but then turns off with lights flashing a code:
Preheating – 4 blinks
Heating – 3 blinks
I can see the igniter glowing red hot.
As the igniter is glowing, the voltage on the terminals to the gas safety valve rise up to 3VAC. But then everything clicks off and the error code blinks as described earlier.
Is it the safety valve or is it the control board?
Or both?
The control board relays seem to be clicking strongly.
Thermador Range/Stove/Oven Safety Valve - Bosch OEM Part #00605061
Is there a way to check the safety valve on a bench?
It says operating voltage 3.3VAC.
Any suggestions appreciated.
This range is a bear to work on.
I’ve never seen so many screws.
And the stove top burner heads are seized up.
Does anyone know of a way to get the burner heads removed without too much destruction?
I am prepared to buy replacement parts for 4 out of 6 of the burner heads.
What a mess!
Thank you in advance for taking the time to read this.
Best wishes for the holidays.
