I hope someone can help me.
My Thermaor range oven turns off and on. I had a friend it looked over and thermostat and relay are working fine. He thinks may be the valve. Since the parts are so expensive I want to make sure that’s the next thing I should look into. The lights goes on for the oven, top burners are working, ingnitor stays on. I smell gas though. Thanks!
[QUOTE=fullmoonclay;332407]…My Thermaor range oven turns off and on…[/QUOTE]
Can you post more detailed description on the problem?
Thanks for getting back to me. Oven takes a long time for the gas to engage. The ignitor glows, then after an extended period of time the gas finally goes on. The burner works for a bit and goes off then starts cycling on and off. At this time the ignitor is still glowing and we have tested there is 120 volts at the dual valve. Does the ignitor sense the flame or would it be the dual valve?
The igniter can be bad even if does glow if it does not draw enough current (more than 3.2 amps) to open the gas valve within 60 seconds.
- The oven Bake igniter AP2832933
Here are the breakdown diagrams and Replacement parts for THERMADOR PRG304US | AppliancePartsPros.com
Thermador MBY microwave turns itself off after 2-3 seconds periodically. I read that the push-on connector of upper door latch may be going bad. Can anyone tell me the thermador part number for a new push on? Additionally, can you recommend a tech in Austin, Texas who can perform the repair? Thanks, Fred.
Hi Gene, Thanks for the reply. I am trying to locate a meter right now. If it reads more than 3.2 amp should I replace the valve next?
[QUOTE=fullmoonclay;332490]Hi Gene, Thanks for the reply. I am trying to locate a meter right now. If it reads more than 3.2 amp should I replace the valve next?[/QUOTE]
No. Just post the results.
[QUOTE=fcyn77;332467]Thermador MBY microwave turns itself off after 2-3 seconds periodically. I read that the push-on connector of upper door latch may be going bad. Can anyone tell me the thermador part number for a new push on? Additionally, can you recommend a tech in Austin, Texas who can perform the repair? Thanks, Fred.[/QUOTE]
Fred,
This is very sophisticated oven and you have to find a guy who really knows it. Try to use Service Magic web site.
Hi Gene,
The igniter had less than 2.8 amp. We will get the igniter!
Thanks for your help!
Hi Gene,
I’ve received the igniter but our original one has 2 separate connecters with like the image above but the new one I’ve just received has a single connecter for both wires. Can we replace them with separate connecters?
Yes. You can cut off the plug and connect the igniter using a high temperature porcelain wire nuts AP5641944
It sounds a bit strange why the igniter you received, if ordered it from Appliance Parts Pros and the part number is AP2832933, looks different. I’ll forward this information to their customer service.
[quote=Gene;334912]You are welcome. Keep us posted.
Gene.[/quote]
Gene - how do you install this part? Do you have to take off the kick panel as well as the panel that holds the electrical wires to reach the screws to take off the old ignitor? Thanks much! I have the same issue and just ordered my ignitor.
The installation instructions are attached to the reply.
Removing the Bake burner and igniter - PRG and PRD.pdf (778.4 KB)
Hi! Just wondering if changing the igniter worked ok??
