Oven light flashes 2 times then heating light flashes 2 times. Lights flash all the time, oven on or off. Large oven does not work at all, 12" oven warm and proof modes work, but not bake ar broil.
I am having the same problem with mine. Model: PGR484GGLP This happened after a power outage. I would like to find a service manual or a schematic I would even pay for it… I have had it with the lack of support from thermador. Any help would be appreciated.
Like I just posted for another member, the 2/2 is a bad control board.
The part number is 00709786 and it’s location is most likely on the back, though it depends on the serial number. In November 2004, Thermador moved the control boards to the top, under the burners.
KC
KC was right the board fixed my problem. Should have done this 6 months ago.
Super easy to change part. Just need tractor to pull stove out.
Thanks again
Jake
