Thermador model prg366eh/06
**Brand:**Thermador
Model Number prg366eh/06
Main Symptom: stove top spark igniter does not click or spark when the gas is turned on
What happens & when: the part that clicks and shoots a spark when the gas is turned on no longer Sparks. It’s the back left hand burner. If I use a lighter once the gas is open it’ll turn on fine. I would like to find the part that makes it spark. If you turn on any of the other burners you can see the spark and hear the click click. I have no click click or spark. I know this model is older but I’m hoping I can still find the part. If you can help me please Guide me to the correct apart.
If there is no visible spark even with the other switches tuned on, the spark module is not sending power to ,that igniter. You would need to replace the spark module. To verify this, switch the leads from the spark module to a working igniter and see if the one in question lights up. the spark module number is 00619017 Re-Ignition Spark Module | Genuine Bosch OEM In Stock
