I have one of the X lo burners not working. Initially, problem was intermittent but won’t work at all, now. Burner behind it still works. I have checked the power to the igniter and it is not getting any power when try to turn it on. Nor am I getting any gas.
Since I am getting no power out of the gas igniter/re-igniter, do I need to replace that module or could the Simmer Control Module be causing the problem… or, both?
The Lo X front unit is now working. (it had been intermittent) BUT, when it tries to turn off while using the Lo X it makes a multiple clicking noise and the unit does not turn off while the clicking noise is happening. The noise seems to be coming from the left side of the stove… perhaps, close to the solenoid. Could it be the left solenoid or would a bad potentiometer on the front Lo x burner cause the clicking of the solenoid? Thanks for getting back to me. Simon.
