Thermador gas oven won't ignite/stay on
[FONT=Arial][COLOR=#000000]Hello,[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]Here is a summary of what I’ve come across :[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- Stovetop burners are working fine. [/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- Setting the temperature and heating method (ie. bake/convection/broil) does not ignite the gas. The igniter is heard but no results.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- The oven fans are on and are circulating.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- The gas is on and drawn out by the fans.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- Removing the bottom cover and flame spreader that covers the burners shows that everything is clean and unobstructed.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- Manually lighting the burners will ignite them and the flame is consistent throughout.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]- Placing the flame spreader cover back over the burners immediately extinguishes them.[/COLOR][/FONT]
[FONT=Arial]- Attempting to ignite the oven using the controls but with the flame cover off will not ignite it.[/FONT]
[FONT=Arial][COLOR=#000000]Of course our extended warranty just ran out a couple of months ago.[/COLOR][/FONT]
[FONT=Arial][COLOR=#000000]Can someone tell me what the problem is, the location and appropriate parts number(s) to fix this? Thanks in advance.[/COLOR][/FONT]
Hello,
The model number you posted does not come up. Please verify and repost it.
Hello Gene,
Thanks for looking into this but yes that is the correct model # for the Thermador Pro Grand 30" gas unit. This model was later replaced by the PRG304US if that helps at all[FONT=Times New Roman][SIZE=3][COLOR=#000000]. [/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=Calibri][COLOR=black][FONT=Arial][/FONT][/COLOR][COLOR=black][/COLOR][/FONT][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000][/COLOR][/SIZE][/FONT]
Hello,
Per the breakdown diagrams and Parts for Thermador PRG304US - AppliancePartsPros.com in this oven are one Bake burner and one Broil burner. Both burners have separate glow bar flat igniters (#14 & #31 at the diagram). Both igniters are absolutely silent by design, so my first question is: how could you hear them? [QUOTE]…[FONT=Arial][COLOR=#000000]The igniter is heard…[/COLOR][/FONT][/QUOTE]
The second question is: Can you see Bake or Broil igniter glowing when you choose Bake or Broil?
[FONT=Arial][COLOR=#000000][/COLOR][/FONT]
Sorry, please ignore ‘the igniter is heard’; should have read Oven/Heat lights on - cut and pasted a previous revision.
The PG304BS doesn’t use the same igniters as the PRG304US, it uses a spark electrode. Having a look at it again, I cannot see a spark being generated. Should it be visible? However as mentioned earlier, manually igniting it works until the flame spreader cover is installed on top, at which point all of the flames are extinguished
While these 2 models may be different, I was hoping that by applying the same troubleshooting steps one might be able to basically pin-point the problem area. Perhaps this won’t work in this case? Thanks.
Unfortunately they are absolutely different and the troubleshooting should be different too. I could not find any information for the PG304 model and not able to provide any instructions for you.
A spark should be pretty visible and if you don’t see it then the problem can be a bad wires, a bad ignition switch or a bad spark module. This is the only what I can tell you without more technical information.
Thanks again for all your time.
Hello again,
After digging a bit more, I found that the actual model # is PG304BS/12. While your site claims to carry parts for it, they are not online.
With that bit of additional information, would you now be able to determine where the problem may lie?
Thank you.
I found the parts list but could not find the electrical schematic, so my instructions are not going to be very sharp.
The ignition system for the Bake consists of two parts: the igniter at the burner and the gas liter module which can be inside the control panel, in the burner box or on the back of the range. I would suspect the gas liter module. Also it is a good idea to check the wire between the Bake igniter and the gas liter module.
Parts_58300000103847D_PG304BS_12.pdf (400.1 KB)
I will order this part from you guys but have one further question :
While replacing this will most likely resolve the oven lighter issue for both the broil and bake functions, does this module tie in to the fact that after I manually light the bake igniter, the burner flames are extinguished almost immediately after placing the flame spreader cover back on or is there another component involved? When I ignite the oven burners without the placing the flame cover back on, the burner flames routinely extinguish within 25 - 30 seconds of being lit and the gas flow automatically shuts off.
Thanks again.
First of all this gas liter module has nothing to do with Broil. It controls only Bake ignition.
The spark igniter is also the flame sensor and the feedback goes through the module to the gas solenoid. If it does not sense the flame then the gas solenoid will shut off the gas flow.
Hello,
Here is a summary of what I’ve come across : Model #PRG364EDG/06
  • Stovetop burners are working fine.
  • Setting the temperature and heating method (ie. bake/convection/broil) does not ignite the gas. The igniter is heard but no results.
  • The oven fans are on and are circulating.
  • The gas is on and drawn out by the fans.
  • Removing the bottom cover and flame spreader that covers the burners shows that everything is clean and unobstructed.
  • Manually lighting the burners will ignite them and the flame is consistent throughout.
  • Placing the flame spreader cover back over the burners immediately extinguishes them.
  • Attempting to ignite the oven using the controls but with the flame cover off will not ignite it.
Nothing changed since 2013 :)).
You may want to check the wire between the oven burner igniter and the spark (ignition) module.
If there is nothing wrong with the wire, the spark module would need to be replaced.
The spark module AP4511814
Good luck.
[quote=haril79;902590]Hello,
  • Attempting to ignite the oven using the controls but with the flame cover off will not ignite it.[/quote]
You might be talking to a bot. They seem to be getting into the site lately. I will say they are getting a lot smarter. Their posts almost make sense.
Thank you ThatGuy. I did pass it over to the Admin.
