Thermador conversion to LP
I just got an older Thermador range in good shape. It is natural gas and I’d like to convert it to propane if possible. It is a model number PRSG364GDS. Does anyone know if there is a conversion kit available to make this switch.
Thanks.
[COLOR=#333333]The accessory number for the kit was PROLPKIT, but it’s no longer available. I’ve attached the conversion instructions which gives the orifice sizes, which can be given to your local LP company. The LP company can then let you know if they can drill out some blank orifices for you. [/COLOR]
PROLPKIT.pdf (336.0 KB)
Just a question on the kit. Do i only need orifices? because the manual has many other parts which are not available. I also found this kit which only appears to have orifices but not sure is for this model (PRSG364GDS)
Thanks,
Abhi.
