**Brand:**Maytag
**Model Number:**LAT9704AAE Main Symptom:The spin cycle doesn’t end What happens & when:All the wash, rinse, agitate and spin cycles work but the machine will not shut off after pumping out all the water
Ultrarod, does the timer get stuck in a specific position, or does it continue through the cycle and the motor just doesn’t stop when the timer reaches the off position?
I had to replace the timer this past November, I purchased it from you guys and it seems to be working fine it just acts like if it had a sensor/switch that tells it the water is all gone to end the spin cycle is not working.
When the failure is occurring, if you unplug the power cord and access the pressure switch in the console, the yellow wire from the pressure switch can be disconnected and the terminal tested for continuity to the terminal with the gray and white wires. Is there continuity at these terminals?
