the dishwasher won’t start to cycle througha wash, when I push the cancel/drain button the moptor starts up, but doesnt cycle through the wash, soon after it quits and the clean light is still blinking… Help
Scotty,
The blinking clean light indicates a water heating problem,
[B][FONT=Swiss721BT-BoldCondensed][SIZE=1][FONT=Swiss721BT-BoldCondensed][SIZE=1][LEFT]PROBLEM: Stopped Running, Will Not Start and Clean LED[/LEFT]
Blinks 7 Times, then Repeats (Water Heating Fault)
Most of the time , it’s due tp a low water temperature(minimum of 120 dgrs. in the tub on the first fill) but could also be a part malfunction( open heater circuit, hi limit thermostat or loose wire connection.
You’ll need to reset the control board,
[FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1][LEFT]To invoke the Diagnostics Cycle, perform
the following key presses or actions in less than
6 seconds while in standby mode:[/LEFT]
Heated Dry [/SIZE][/FONT][/SIZE][/FONT][FONT=AdobePiStd][SIZE=1][FONT=AdobePiStd][SIZE=1]➙ [/SIZE][/FONT][/SIZE][/FONT][FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1]Normal [/SIZE][/FONT][/SIZE][/FONT][FONT=AdobePiStd][SIZE=1][FONT=AdobePiStd][SIZE=1]➙ [/SIZE][/FONT][/SIZE][/FONT][FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1]Heated Dry [/SIZE][/FONT][/SIZE][/FONT][FONT=AdobePiStd][SIZE=1][FONT=AdobePiStd][SIZE=1]➙ [/SIZE][/FONT][/SIZE][/FONT][FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1]Normal[/SIZE][/FONT][/SIZE][/FONT]
[FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1][/SIZE][/FONT][/SIZE][/FONT]
[FONT=Swiss721BT-RomanCondensed][SIZE=1][FONT=Swiss721BT-RomanCondensed][SIZE=1]Allow the control to run the whole diagnostic cycle(takes 5 to 10 minutes)to off.[/SIZE][/FONT][/SIZE][/FONT]
[SIZE=1][/SIZE]
[SIZE=1]Run the hot water faucet at the kitchen sink, to flush any cold water from the pipe and start a new cycle. If the clean light is flashing again, you’ll need to run circuit checks on the heater element and thermosta and wires.[/SIZE]
[SIZE=1][/SIZE]
[SIZE=1]Good Luck,[/SIZE]
[SIZE=1][/SIZE]
[SIZE=1][/SIZE]
[/SIZE][/FONT][/SIZE][/FONT][/B][/SIZE][/FONT][/SIZE][/FONT]
