Temperature sensor problem
I have a Samsung front load washer .
Lately it has started erroring during the cycle with SUDS displayed on the led readout. I switched to HD detergent per the owners manual, and it ran fine until 2 days ago.
2 days ago it played a new tune in the middle of the cycle and displayed a error code that looked like 2 capital “E 's” with the top line of the first “E” missing. My manual says there is a temperature sensor error, and it will no longer reset.
Well the unit is 2 years old, and Samsung says its out of warranty, BUT there is a recal on other models made at the same time because of water getting on a circuit board via the temp sensor and causing fires. Samsung says my unit is not part of the recall.
I have called around for service, but most want $95 just to come out. I have looked online for a temp sensor, but no part with that name exists for my modlel front load washer.
Has anyone run into a similar situation?
Does anyone have any advise for my next step?
I payed over $1000 for this machine, and its only 2 years old…I would think I could have gotten more life out of it before it died on me like this.
I am not afraid to open it up myself, but it would help to know what I am looking for before I start unbuttoning it, anyone have any suggestions?
Unfortunately I’m not familiar with Samsung washers. Maybe somebody else on the forum can help you better. Also you can buy the service manual for this washer.
  • The part number for the service manual is AP4258912
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Well I finally bit the bullet and blindly started taking the washer apart.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Here is what I found:[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]First, 2 wires (orange and white) running to some type of sensor at the bottom of the drum were cut completely in half. It looked like the strap that held them in place had worn completely through the wires.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Second, the wire bundle that comes down the front right side of the cabinet that feeds the door lock and door open switch were also worn and bare.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]What was the biggest surprise to me was the way that Samsung had treated the wires during manufacture. The wires were not in raceways or wire loom, but wrapped in yellow and red electrical tape. In areas where they were clamped, the clamps were not sized correctly and the assembler just wrapped enough tape around the wires to get the clamps to hold.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I can see clearly why they would have had to recall their units because of the possibility of fire. The treatment of the wire inside the cabinet is cheap and shotty. Wires are not protected in pinch points and eclectic tape is used instead of wire loom to protect it from chafing.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I took pictures of each repair I made, where I spliced the broken wires, and the wire loom used to protect the wiring. The repairs took me a total of 3 hours, at least 1.5 hours of that was figuring out how to get the cabinet apart, and repairs were made more difficult because I did not attempt to remove the boot that goes between the door seal and the drum.[/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Times New Roman]The washer runs like new now, I let it cycle through 1 complete full load before I went to bed, and it had no issues. [/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
It is worth mentioning…the Machine is only 2 Years Old :mad:
Thanks Stevetra! I have a Samsung Washer also model # WF316LAS/XAA with the same error message tE Temperature Sensor problem I took off the front panel and whala! a wire had frayed off just like yours except my wires were orange and yellow, the yellow needed to be repaired I took the boot off and it was really a snap to put back on I recommend taking off the front retaining wire with a small screw driver, it has a spring on it and expands for easy removal and replacing. thank again!
Art
HI there.
I had same problem with my samsung washer?!!!
well after couple of days researching and calling
I have find out error code tE is mostly related to
temperature sensor wire and connection problem
I took front panel off and with help off my flash light
I find out connection to sensor located under tank is bad and
rusty ,I clean and cut bad wire and reconnected wire to sensor
and it did work ,after I turned on my machine it was ok and error
message was gone.I hope this is helpfull.
thanks
I like to add this too, wires are orange and yellow
yellow wire was rusty and almost disconnected from a white plug
which was going to sensor,I had to cut and re connected
and it did work very well.
thanks
just going through the same thing, the tech we have out that was sent through Samsung is struggling with it and I just helped him figure it out
My machine is WF306BAW/XAC. Same error code Temperature Sensor. I opened front panel, Inspected the conector under the trunk, the connetcor is fine, no chaffing on orange and white wires. I didn’t open the wire bundle to inspect single wire. I closed panels, and the error code still there. washer didn’t work.
I checked the orange and white wires under the drum again. The white wire was brocken at the wrapped bundle near standoff near the connecter. I connected the wire, and the washer works properly now.
I hate the Samsung customer service. They did not help at all.
You guys rock. Same error code. Found this forum via Google. I read all of your replies, so fumbled my way through taking the panels off and disconnecting the gasket around the drum. And there she was…white and orange wires, white one sheared in half. 45 minutes of mostly sweat work, and we’re doing laundry again. God Bless the Internet!! lol :slight_smile:
Same problem on samsung wf 206. tE error. orange and white wires both sheered off…no no apparent cause they appeared to be cut…i think it happens from having a un level machine as wiring harness is attached to drum. respliced wires back together and put back together. did this by pulling whole sensor out as plug is siliconed together to prevent water into wires. this sensor pulls right out of rubber plug.this forum rocks and now machine works great again.
[QUOTE=ronyjahany;656220]I like to add this too, wires are orange and yellow
thanks[/QUOTE]
I, too, am having problems with the te sensor code on my Samsung washer. Looks like they may have tried to fix this error as all my wires are bundled. I can’t see any breaks or rusty wires, but if someone could tell me where to look for the temperature sensor or what it looks like, I could look more carefully in that area. Also, they must have changed the wire colors because I have orange wires in a couple of places, but no yellow or white wires.
Any help would be appreciated. :confused:
[quote=Pwoodruff;862645]I, too, am having problems with the te sensor code on my Samsung washer. Looks like they may have tried to fix this error as all my wires are bundled. I can’t see any breaks or rusty wires, but if someone could tell me where to look for the temperature sensor or what it looks like, I could look more carefully in that area. Also, they must have changed the wire colors because I have orange wires in a couple of places, but no yellow or white wires.
Any help would be appreciated. :confused:[/quote]
I took the front off my washer not knowing where the sensor was myself. Well don’t do that! Ha The sensor is in the rear of the machine and the orange and white wires were the problem for me too. Same issue the machine is seeping water slightly at some point and has caused corrosion on the wires, but the failure was because the white wire had broken loose at the connector just below the motor in the rear of the machine. The temp sensor has 2 blue wires coming from it and connects thru a 2 pin connector to the orange and white wire. Good luck!
REF. my machine was a VRT Samsung model WF350
My 4 year old front-load Samsung started this last week. I found the thermister, tested it for resistance change when exposed to temperature changes. Tested good, but replaced it anyway.
New thermister tested identically. Traced wiring harness and found lack of continuity in yellow wire going to PCB (motherboard) connector. Spliced in a jumper, verified continuity, and still have same error code! SO, ordered new PCB from Appliance Parts Pros. Just arrived and will install soon. More to come!
Good luck!
If you would need any advice, post the complete model number of the washer.
