Electrolux Range:
EW30DS75KS4
Issue: Takes 30 or more minutes for the oven to heat to 425 degrees. After 30 minutes oven reached at 350, pressed rapid heat option and display showed 394 degrees and quickly reached 425.
Will replacing the relay board on the back of the range enable the oven to heat to 425 without the rapid reheat option?
Range is 14 years old
Replaced with New OEM Parts:
Temperature Sensor
Bake Element that now reads 23 Ohms
Also, make sure the broil element is good, ohm it out as well before replacing the relay board. Some models use the broil element to help pre-heat the oven.
318255815, it is in the top portion of the oven cavity. If the bake element is not visible at the bottom, that means it is hidden under the bottom panel. It would have to be removed from the back.
