[LEFT][COLOR=#000000]My Tappan electric oven and broiler stopped working at the same time. Stovetop works fine. All wiring good with 120V and 240V. It was working fine for hours then just quit heating? Could it be the control board?
If the unit stays in pre-heat then odds are that it is the control board.
You may also need an overlay as most of theses are peel and stick and can be difficult to remove. Sometimes heating it up with a hair dryer helps.
