Tappan oven/stove not heating up
Today (Thanksgiving of all days) my Tappan elec stove quit working w/o notice. It was working fine for hours then just quit heating? The element lights come on (and the oven light) when the knobs are turned on but they are not heating. The oven is not heating either. I must mention the clock/timer has not been readable for some time so I cannot see any codes or numbers.
I have researched the part number (ap39556392) for the clock/timer and it’s cost is around 100 dollars. I just want to make sure if this may be the problem before ordering the part and spending money if that is not the problem.
Thank you in advance for any help.
Replacement parts for Tappan TEF326FBA Tappan/range | AppliancePartsPros.com
Although the stove top elements and oven elements both run off of 240 volts, they are controlled separately. Since none of them work I would lean towards a power problem.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
There may be a low cost repair for your dim display, see the following.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1058-thermador-display-very-dim.html?highlight=dim+display
