Tappan dishwasher not draining
Hello, my Tappan dishwasher is not draining. I’ve checked the drain hose, the hose going to the pump, and the pump. I also took off the spray arm and filter and checked for any clogs. Everything looks clear. I watched the drain hose going to the sink while the washer was in the drain cycle. There is water going through the hose. There are a lot of air bubbles. I hear a lot of air coming out of the air gap. The air gap did not seem to be that noisy when the washer was working properly. Then when the drain cycle ends, I see some of the water in the drain hose go back into the washer. Any suggestions? Thanks for your help.
Hong-Chih Kuo filled in at closer for the Dodgers, escaping trouble for his second save in three San Diego Chargers Jersey chances. Juan Uribe drew a one-out walk andCheap nfl jerseys Aaron Rowand singled to put runners on the corners. Buster Posey struck out and Edgar Renteria flied out to right to end it.Billingsley allowed two runs and five hits in six innings, struck out three and walked two.The Dodgers turned five double plays for the 11th time and first since Sept. 4, 2007, against the Cubs. The franchise record is six, set on Aug. 5, nfl jersey1956.Andre Ethier tied the game with a sacrifice fly in the nfl jersey third inning then Ramirez hit a go-ahead double, but it didn’t hold.
