If your Roper dryer, model RED4340SQ1, is taking multiple cycles to dry clothes, there are a few things we can check to narrow down the problem. The most common causes are restricted airflow, a heating problem, or a thermostat that’s not cycling properly.
I’d start with a couple of simple checks before replacing any parts.
1. Check the dryer vent
A partially clogged vent can make the dryer take much longer to dry, even if it’s heating normally.
Clean the lint screen.
Check the vent hose behind the dryer for lint buildup, crushing, or kinks.
Check the outside vent hood to make sure air is flowing freely.
Quick test: Disconnect the vent hose from the back of the dryer and run a small load on a heated cycle for about 15–20 minutes. If the clothes dry noticeably faster, the problem is likely a restriction in the home’s vent system.
You can perform this test briefly on an electric dryer, but don’t use it this way for regular drying.
2. Check whether the dryer is heating
Start the dryer on a Timed Dry cycle with High Heat.
After about 5 minutes, open the door and check whether the clothes and inside of the drum feel warm.
No heat: We may need to check the heating element, thermal cutoff, operating thermostat, or incoming power supply.
Some heat, but clothes stay damp: Restricted airflow or a thermostat problem becomes more likely.
Normal heat: We’d want to look more closely at airflow and whether the dryer is maintaining the correct temperature.
