Switch replacement
I need to replace the dual burner infinite switch. How do you access behind the control panel where the switch is located to swap out the switch? I see two screws at the front base of the control panel, but the heat shield visor blocks access to the screws.
Thanks,
Greg
Greg—I’m looking for help with the same problem. Have you found an answer?
