Switch Membrane
Ordered Jenn-Air WW30430B part from Applicance Parts Pros and installed SWTCH-MEMB 71001873 because the previous membrane had a defective upper oven touch control. Simple enough, install by plugging in and I get nothing? Now we have no upper or lower oven. Clock flashes but cannot set it either.
Suggestions? Thanks, Hutton
Hi Hutton,
You may want to take it apart again and make sure the membrane switch ribbon cable is firmly plugged into the control board.
If it would not help, then inspect the tracks in the ribbon cable for haircracks using a magnifying glass. Post the results.
