Switch from Celsius to Fahrenheit
Stove at some point was switched from Fahrenheit to Celsius. Have looked all over for a user/operations manual for the stove but have had no luck. Any idea as to where I can get the user/operator manual or switch the stove back to Fahrenheit?
Regards,
-Eugene
Eugene,
The model number you posted does not come up. It might be incorrect, incomplete or just too old.
You can try this: Hold either timer keys down on power up. The right digit will display “F” or “C”. The temperature display can be toggled from C to F by pushing the Broil key.
[SIZE=5][COLOR=red]Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps![/COLOR][/SIZE]
[COLOR=black][FONT=‘Tahoma’,‘sans-serif’][COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]The temperature is preset at Fahrenheit, but can be changed to[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]Celsius.[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Bold’,‘sans-serif’]1. [/FONT][/COLOR][COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]Press and hold the upper oven BAKE and CANCEL pads[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]for 3 seconds. A beep will sound and the current setting[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’](°F or °C) will appear in the display.[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Bold’,‘sans-serif’]2. [/FONT][/COLOR][COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]Press AUTOSET to change the setting. Wait 4 seconds for the[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]new setting to be accepted.[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]If AUTOSET is not pressed within 30 seconds, the control will[/FONT][/COLOR]
[COLOR=black][FONT=‘HelveticaNeue-Roman’,‘sans-serif’]return to the existing setting.[/FONT][/COLOR][COLOR=#006600][FONT=‘Arial’,‘sans-serif’][/FONT][/COLOR]
[/FONT][/COLOR]
