I have a GE prodigy washer, Model # WPSE4200A0WW. The tub was sitting very low in the washer and when the tub fill up with water it causes the pulley system and spring clip on the clutch assembly to grind against the bottom of the washer during agitation and spin cycle.
I’ve checked online posts and others recommended replacing the four suspension rods (2 yellow - front, 2 black - back. I ordered the replacement parts for my model
AP2046168 (WH16X544) Suspension rod & spring assembly (black) 2
AP2046167 (WH16X543) Suspension rod & spring assembly (yellow) 2
and replaced each of the suspension rods. I loaded the washer on its lowest water setting and again even with only water, the spring clip on the clutch pressed against the bottom of the washer. Are the replacement parts defective or is there something else going on here.
Would appreciate any help you could provide.
