The 20W bulb for range surface light shorted out. Now replacement bulb stays on continuously, regardless of control panel function.
Pretty sure it fused a relay or SCR but don’t have a wiring diagram on the unit.
Any help here would be appreciated
[quote=kb4ob;549956]The 20W bulb for range surface light shorted out. Now replacement bulb stays on continuously, regardless of control panel function.
Any help here would be appreciated[/quote]
I just dropped lower panel to expose sockets and located the 2 main wires cut one and spliced in a 120v switch. Now it turns on/off
Rob
