Surface Indicator Light stays ON/electric range
One of my burners sparked and triggered my circuit breaker to turn it off. When I replaced the burner and fixed the wiring, this burner worked fine. However, one of the surface indicator lights that shows that one of the burners is on, never goes off now. If all the burners are not in use and are turned off, this light wll remain on. Is this dangerous and will it cause a fire? How do I fix this light so that it will function normally. Thank you for your help.
We have the same problem. can someone help? Our Range oven is Kenmore 911.95499301. It is 8 year old. Thanks
You have there a shorted out infinite switch (the one operates the replaced element).
For the large element use this one
7403P239-60
For the small one 7403P238-60
Here are the breakdown diagrams and Replacement parts for Maytag MER5530AAW RANGE- S/C F/S ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Hi.
Did you have any similar problems as the previous post?
Please describe in a bit more details.
Thank you.
Simon.
