Surface element not working
Brand: Samsung
Model Number:NE595R0ABSRAA
Main Symptom: surface elements
What happens & when: the right front surface element on my Samsung range won’t turn on. The red indicator light turns on and makes a clicking sound as if it was on but nothing happens to either the inner or outer rings of the surface element. It went all at once about 6 months ago and I believe it has something to do with the surface element itself (part #DG47-00023A) or the energy regulator (part #DG44-01009A). I may have access to a multimeter if necessary. I have also just recently ive noticed the left front surface element runs hot. after i turn it off, it takes l
onger than expected for the surface element not to be red hot and for the indicator light to turn off.
A quick question before we dive in to in depth diagnostics. Does the front right eye work on either setting for size?
