The electronic igniters stopped working on the cooktop surface burners. Is this something that I can replace/repair myself? What exactly is the problem? Is there a reset or something? Thanks.
Hi Patrick,
Most likely the problem is a bad spark module. The correction is to replace the spark module. This job is not too difficult if you know how to handle a simple tools. The instructions are attached to the post.
- The spark module AP6009457
Here are the breakdown diagrams and Parts for Whirlpool KGST307BWH2 Range - AppliancePartsPros.com
Removing the spark module and the cooling fan motor.pdf (338.4 KB)
