Surface Burner Switch
While cooking, a pot boiled over and I believe leaked through to damage a burner switch. On this model, it is the back-left burner (8"). There are different switches listed as part # 19 in the manual, with a variance in price. I’d like to replace it with the least costly part, but, I certainly want to be sure it is compatible - and safe.
Some switches list wattage, and the lesser expensive ones do not. Any advice?
Thanks for your help.
There are 3 different heating elements used in your cooktop - 6"/1200W, 8"/2100W and dual 9"/3000W. The left rear burner has the 8" heating element and the correct infinite switch for this burner is the [PART]AP2631452[/PART]
Unfortunately this is the most expensive one.
Here are the breakdown diagrams and Replacement parts for General Electric JP350WV1WW Electric range | AppliancePartsPros.com
