SUDS and F35
I have a Kenmore Elite HE5t Washer, model number 110.47789701. We have had it less than 2 years. Recently it started giving the SUDS and F35 codes. If we turn it on and off several times (up to 10x sometimes) it will work. I’ve determined based on previous posts that it is the Water Level Switch and I understand it’s on back order (part # W10415587 according to sears parts direct). We discovered that the woolite detergent my wife was using was not HE. I think this is the source of our problem and we’ve stopped using it. We are moving in about 2 weeks cross country and my main question is this… if we continue to use it as we have been (with the proper detergent of course), will we do any further damage? I think I should be able to do the repair myself when we get to California.
Thanks,
Russell
You should be fine continuing to use the machne as is, but after you move be sure and get it fixed and cleaned out.
Good luck with your relocation and your repair.
