Front Loader washing machine is not working properly. We first get an SUD error and then a F21 error( drain problem) …the machine does not reset after we select the “pause/cancel” button…the machine continues to drain completely.. so it appears the pump is working
Hi
Even though the pump seems to be working correctly I would still remove the pump and inspected it for foreign objects.
