i have a whirlpool front load washer giving sud and f35 error code hvae replaced pressure switch checked pump no obstructions no where did 3 loades and error codes came back seems like no one knows what the culprite is anyone out there know if you say it could or is the cc board please explain how to chec k it to make sure that is the next problem
thanks guys and gals
While there are some tests for the control unit, in the end they are pretty unreliable and what even the Whirlpool techs do is change out the part to see if that fixes things.
If you buy a new control unit from this site and it does not fix the problem you can return it, so I suggest you try that.
