Hi, my dishwaher is stuck on and will only run the quick clean cycle. I can run no other cycle. I tried resetting the the breaker for 30 minutes, no luck. Has anyone seen this type of problem before?
Thanks,
Steve
Thanks,
Steve
According to he tech sheet your quick clean cycle button is probably stuck.
Nat
[quote=libertyappl;36364]According to he tech sheet your quick clean cycle button is probably stuck.
Nat[/quote]
[COLOR=#333333]Hmm, it’s a touch pad and the contact points are clean and free of moisture or corrosion, no way to get stuck, unless there is a micro switch on the control board that enages when the touch pad is depressed. I guess I’ll just replace the control board.[/COLOR]
[FONT=Calibri][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
Not the control board, you need to replace the touch panel, you have a stuck key.
