washer used to fill then nothing no wash you could press cancel and it would drain, now front panel is stuck on “clean” tried unpluging no difference what if anything can I chek next?
Is the clean light blinking or just stuck on? Did you check and see if the unit is in child lock program?
light is blinking i actually counted 7 blinks then pauses and repeates,also cheked unit is not in child lock out mode, any sugestions ?
That means the temperature sensor didn’t see hot enough water. To fix this here is what you will need to do. Press Heated Dry, then Normal, then Heated Dry, then Normal back and forth within 5 seconds. This will put it into diagnostic cycle. Once it is finished you should be ok to use it. Try getting your water hot at the sink to prevent this from happening again. If you are getting the water hot at the sink, then you may have a heater problem. Hope this helps. Let us know what you find.
Jeff I would like to thank you and APP the clean light stoped blinking and seems to be ok this weekend Il put it under counterfor the real testl but i’m pretty sure it’s a done deal THANKS AND GOD BLESS
Your welcome! Glad we could help!
