I used the stovetop last evening and everything worked fine. I turned on the front right burner this morning and no indicator light came on. I checked the other burners with the same result. The “element on” light is not working either. I can hear the burners come on and they do begin to heat, although as soon as I realized that they were heating, I turned them off. So…working burners but no working indicator lights. Thanks for your help.
Looks like there is a problem with the neutral line. If the oven clock still works fine then the problem is somewhere inside the range. If the clock does not work too then the problem can be outside the range.
