My oven will not turn off. I will turn it off but the oven will stay on warm at about 80 to 100 degrees. It works correctly and at temperature when I use it. Anyone know what I need to replace to get it to turn off completely.
Mark,
You’ve most likely have a shorted wire to one of the oven elements, You’ll need to slide the range out, remove the back panels, and check the wires to the elements, if they are shorted to the chassis, there will be a constant 120 VAC to the element and causing he element to partially heat, even in the Off position.
If there are no damaged or pinched wires, you’d have a bad contact in the oven thermostat.
Good Luck,
