I purchased a home that came with a Tappan Range. The stove top works, but the oven stopped working. The gas comes on but the oven does not ignite. I need to see where I can find the part and a manual to show how to install it. Thanks!
same here but i don’t understand why its not working what do i need to do to fix it?
[QUOTE=jvidosh1;490015]I purchased a home that came with a Tappan Range. The stove top works, but the oven stopped working. The gas comes on but the oven does not ignite. I need to see where I can find the part and a manual to show how to install it. Thanks![/QUOTE]
Does the Bake (bottom burner) igniter glow while the control calls for Bake?
If it does but does not light up the flame, replace the igniter.
If it does not then you have to have a simple multimeter to perform some troubleshooting.
Check for 120 VAC to the Bake igniter while the control calls for Bake and post the results.
- The Bake igniter AP2150412
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE 30-3991-23-03 Tap(v2) / Gas Range | AppliancePartsPros.com
[QUOTE=katiebrown378;490146]same here but i don’t understand why its not working what do i need to do to fix it?[/QUOTE]
What is the complete model number of the oven?
