The burners do not light, and there is no clicking sound from the piezo igniter…does this just require new parts…?
Most likely the problem is a bad spark (ignition) module. The model number you posted does not come up.
Thank you, Gene…It is a Magic Chef stove, so I imagine that it might be their standard ignition module…could that be right…Duffyk
There are two different spark modules used by Magic Chef. Thats why the model number is so important.
