Stove Igniter Does Not Work
My Stove Igniter Does Not Work On My Gas Stove.
Jack
My Stove Igniter Does Not Work On My Gas Stove. THE AUTOMATIC IGNITER DOES NOT FUNCTION ON 2 OF THE STOVES BURNERS ,THE OTHER 2 IS JUST FINE.
Jack
Hi, Jack.
I need more info, please.When you turn the knobs one by one how many ignitors spark? When you turn on the burners in question is the other spark?
Please, post the answer.
2 of the burners on the right works well .with one spark and there on.The 2 on the left side you turn on there is no sparks but gas is flowing. So 2 right ones are working 2 left ones are not working .
thanks
JACK
Hello.
Most likely the problem is with igniter switches.
Take the top off (you need to take all burners out and lift the top) and switch around good one with one in question. If it will work - you need two switches.
If it wont- replace the spark module.
The igniter switch AP3191247
The spark module AP7216121
Here are the breakdown diagrams and Replacement parts for General Electric JGP336WED2WW Gas range | AppliancePartsPros.com
Thank you. Post the results.
