we had a thunderstorm and the power went out for a few minutes when it came back on the clock and timer on the stove no longer lights up everything else on the stove works is there a fuse or some type of reset or do i have to replace it
Either no power is getting to the clock or it is likely defective.
There is not usually a fuse for just the clock unit, no.
The only ‘reset’ that can usually be tried is totally disconnecting power from the appliance for a minute or two.
If the clock is receiving power but not functioning at all, yes it would usually require replacing.
LINK > Frigidaire FEF322BAWC Clock Unit
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
