My microwave when I turn it on, will not work at all. When I try to turn on microwave the fuse blows out. I tried to fix this problem by changing the fuse in the microwave but the same issue is still happening. When I took out the microwave, I found out that the stirrer blade/antenna/ part 58001197 inside the microwave is broken. Could this be the reason that is making the fuse blow out? I have tried for looking for the part but the part is no longer made/continued.
Thank you.
