Dryer will tumble without heat. The first time I found that the high limit thermostat had melted and i replaced it. I got heat for a few minutes then cold air. I just now replaced the high limit and the low limit (?) thermostat with the hope that this would do it…nope. The high limit had no connectivity either time. The low limit did but I thought maybe it had malfunctioned anyway. So I am out of ideas. The ducts are clear. Any ideas?
Did it show any error code?
How did you know that the vents are clean and the air flow is not obstructed?
No sir. No error codes. When I replaced the thermostats i checked to see that hot air was blowing through the duct work. Didn’t seem to be a problem.
Run the temperature test as instructed in the attached file (page 5) with the vent hose still connected to the dryer and with the vent hose disconnected from the dryer and post the results.
Samsung-Dryer-DV2x - 3x - Fast-track.pdf (885.9 KB)
