I need to replace a leaking drain pump in my Maytag washer and I’m not sure how to get to it. Looking for suggestions and tips to do this. The bottom cover needs to come off I think. Thanks
This service manual should take you through the process.
http://www.servicematters.com/maytag_library/docs/16022937.pdf
Thanks a bunch. With your help it took me less than an hour to replace the pump, and I saved about $120.00 in the service call and labor. And I never figured that the motor had to come out. Thanks again, lss124.
Great, that’s not an easy job and glad to hear you got it done. Thanks for the update.
