Once I have replaced this device is their anything else that I need to look for? I found it burned up because the frig was not cooling on the frig side not the freezer side.
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202255373.pdf
Not a bad idea to check the compressor windings before replacing it as bad/shorted windings will just burn up the new starter.
Be sure to check the winding connectors to the compressor’s case. Usually there is a ground strap or you may have to scrape off some paint.
Below is a site on how to check it
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
