The control switch is stuck . I can’t push or pull on it. The only way I can get it to work is to hold the outer circle and turn it to where I need it. Any way I can unstick it. Lol
No, sounds like a replacement part is in order, but since this is a fairly old machine my recommendation is that you continue with your work-around until it finally fails and then replace the machine.
