Most of the buttons work on the control panel but the start button has been giving me problems and finally now won’t start the dishwasher. When it has started it goes through it’s complete cycle.
Do you think its the black control panel (#5 in your diagram?)
Could be the control panel or the control board (Item 12).
The usual way to troubleshoot this is to check the panel (keypad)with a meter and if it checks out OK replace the control board. Unfortunately they do not publish a pin-out for the panel so you cannot do this. Keypads are usually set up so that a number of keys use the same common so if a number of keys (usually 3 or so) are not working I would replace the control panel. Still a bit of a crap shoot.
Try this first:
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
