Dishwasher is washing good, but there is water left in the tub after all cycles are completed. Drain hose couldn’t be plugged as the water drains throughout the cycle. HELPPPPPPPPPPPPPPPP:(
Do you have an airgap? If not, checkthe drain hose. Does it have a loop before it connects to drain pipe? If no air gap, drain hose from unit must go up to the underside of counter then down to where it connect to the drain pipe or disposal. Good Luck
The drain hose could be partially plugged.
The dishwasher only drains out for so long. If it is partially plugged it will not be able to drain the water fast enough in the amount of time it has to run in the drain cycle.
It has been working great for 4 years and out of the blue it starts this. I took it out from under the counter this morning and ran a quick wash and it worked find and later a normal wash. I did it again after dinner and the water is again standing in the bottom. Sounds like a Repairman, was hoping it wouldn;t come to that.
